Anyone Else Having Battery Problems with the Braun CoolTec Razor?
Hi everyone,
I'm hoping someone here might be able to help. I have an old Braun CoolTec electric razor I believe it's the CT2s model that's about 10 years old, and I'm looking to replace the battery because it got to the point that it only charges enough to give me 3 or 4 minutes tops of shaving time.
I've examined the device pretty thoroughly but can't seem to find any visible screws. The only access point I found is at the bottom where there is a little slot for a flat screwdriver to be inserted but when I insert one and try to use some force in any direction nothing really moves and it feels like the plastic around is going to brake. Has anyone ever opened one of these up and successfully swapped out the battery?
Any advice or pointers would be greatly appreciated. Thanks in advance!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi @gab88078
Here's a video that may help.
Был ли этот ответ полезен?
Счет 3
3 Комментариев:
Awesome video! Thanks very much for the link jayeff much appreciate it! 🙏
из
@gab88078 Hey gab, I hope you will consider making your own iFixit guide to this repair. All you have to do is take lots of pictures as you work, then you can use those to create a guide for those who come after you with the same problem. It's easy, fun and will earn the appreciation of the repair community.
https://www.ifixit.com/Guide/new
Assuming this resolves the issue for you, please be sure to give @jayeff credit by accepting his answer as the solution. That will also let others know right away that you found an answer to your question.
из
Hi Jerry,
It’ll be a few weeks before the new battery arrives, and hopefully that’ll resolve the issue. If it does, I’ll try to put something together to help others—even though the video @jayeff linked really covers everything anyone needs to know.
Thanks again!
из
Добавьте свой ответ
gab буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 41
За всё время: 174
