Can’t find replacement bit
What is the number 4 bit. 3row from bottom closest to the large screwdriver. I order what I thought it was and it was wrong one please help thanks
Это хороший вопрос?
Это хороший вопрос?
@randylane if this is the one you are referring to
then you are looking at the 7mm Hex Security 1/4" Screwdriver Bit.
Был ли этот ответ полезен?
Hi @randylane,
Just to add to the answer above
It's very hard to see but the type/size of tool is shown under every piece.
Here's an image showing what I mean. I've only highlighted a few so as to not confuse the image.
(click on image)
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 184
2 Комментариев
@randylane what kit are you referring to?
из oldturkey03
Manta screw driver kit. When I look at the list I can’t find the exact one. The pics look the same for hex 4mm and hex security 4mm
из randy lane
