Released on July 28th, 2017, The New Nintendo 2DS XL is a technologically-improved remodel of the 2DS handheld. It is the ninth and last redesign of the Nintendo DS line, The console is much larger than the original 2DS model and adds all the features of the updated 'New 3DS' line of systems, minus the ability to play games in stereoscopic 3D on the top screen.
How do I replace my speaker with a broken wire?
When i was replacing my circle pad i accidentally snapped a wire that connected a speaker to the device. Is it possible to replace it? I was able to take the speaker out but i cant find anything that looks like it that isn't a switch speaker. Should i just order a switch speaker? Are they the same size?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi!
Yes you actually can! They are the same size and will fit. There are plenty of tests done and it does fit and work.
Unfortunately, the cable came out the connector completely… so the speaker need to be replaced completely. The speakers aren’t that expensive, so you should be good to go. The connector on the motherboard, is still fine, right? If yes, then just replace the speaker!
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
My pleasure! Good luck with the repair!
из
Добавьте свой ответ
Macaroni and Trees буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 13
За последние 30 дней: 48
За всё время: 318
