ASUS TUF Gaming Laptop - FX505D-DBQ234T with i5-8750H and Nvidia gforce GTX. MFD-2019-05.
Why is my wifi adapter not working?
In device manager the wifi adapter is showing (code 10) error.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi @tarunraikwar
Is the latest Realtek Wireless LAN Driver Version 2024.0.8.107 2019/05/28 installed?
Also check in BIOS - Security (or Advanced) for any settings relating to WiFi e.g. I/O interface or Onboard Configuration to check if the WiFi has been disabled.
Был ли этот ответ полезен?
Счет 1
I have been worked with this issue. The simplest and easiest solution is if there are no software issue or driver issue.
If you go to service centre they will change entire wifi bluetooth module and they will cost you decent amount of money without any reason.
  1. open the back panel (remember that which screw is where)
  2. you'll find wifi + bluetooth module under the SSD.
# plug it out clean the yellow part with eraser or recommended cleaning solution. (I have done it with eraser)
  1. Plug it in.
  2. Tight all the screws back.
  3. Problem solved.
Счет 0
Добавьте свой ответ
Tarun Raikwar буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 55
