Repair and disassembly guides for Garmin GPS devices.
ZUMO XT battery died. Replace with Battery# 361-00077-00? Connector?
Garmin is silly. My ZUMO XT GPS battery went bad. They say I have to send it back. F' that. I want to fix it on my own...or with your help. Battery# 361-00077-00 is what Batteries Plus said I should buy, however, the connector is part of the problem. Anyone have experience in this world?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
@jasonb27686 My information says the battery is a 361-000133-00 but whatever the case may be, none of those are readily available. I would search for a battery with same electrical characteristics (the amperage has some tolerance) and a size that will fit the case. Then cut the wires and connector from the old/original battery and transplant it to the new one. Lets see your original batteryAdding images to an existing question
On the GPS forums, claims are made that the 361-00077-00 fits all Garmin Zumo's but the connector is the real issue here.
Okay, looks like the battery is a 3.7V 3060mAH 11.322WH battery and the Garmin number indeed is a 361-00133-00. Now, the battery itself is a 1ICP5/40/62-2 battery with 3 leads (Positive, Negative and thermal protection). Commonly this means your battery size is 5mm thick (in the case of this battery it might just be 10mm, got a feeling here;-) by 40mm wide and 62mm long. Do a search by the 1ICP5/40/62-2 numbers and see if those match your battery.
If my numbers are pretty identical to what they measure on your battery, something like this (example only) will work
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Jason B буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 12
За последние 30 дней: 71
За всё время: 407
