Volume button not working
Volume button are not working while pressing it
Это хороший вопрос?
Счет 10
13 Комментариев
How to change volume button
из Поделиться
@abhijitdebnath Does the existing answer not answer your question? If not, what's different about your question from the original?
из Поделиться
Volume button repair
из Поделиться
@abhi31782 See the Most Helpful Answer below; your issue has already been addressed.
из Поделиться
My volume button not working
из Поделиться
Показать ещё 8 комментариев
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Посмотреть содержание изображения:
Был ли этот ответ полезен?
Счет 4
2 Комментариев:
Kam karne Wala volume
button Kam nahin kar raha hai
из Поделиться
@pranav55998 could most certainly be a bad volume button flex. To replace this and since iFixit does not yet have a guide for that, use the one from here It is written in Spanish so use a browser that does the translating for you, if needed. The volume button flex is readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Счет 1
Well check for any sort of physical damage near the volume button area if recently your phone is drop down so that can also cause the damage on the button and also check for the latest software version update sometime an outdated software version can also cause these kind of issue as well.
Счет 1
Добавьте свой ответ
Pranav буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 20
За последние 30 дней: 47
За все время: 1,768
