Dell Chromebook 3110 is designed so it can be repaired easily with minimal downtime. Top-mounted keyboards enable ease of service, captive screws that remain attached to the chassis keep materials intact and customized services for K-12 provide the tailored IT support that students need.
Root a Dell Chromebook 3110 2 in 1
is there a way to root a Dell Chromebook 3110, as you would a Android cell phone? would you use the same programs to root it?
Это хороший вопрос?
Счет 0
3 Комментариев
@nick any idea on this one? This is where you enable the developer mode, then use a custom Linux and chroot command or similar right?
из
@oldturkey03 Yep, this is dev mode. Typically used for developer use or someone bought an EOL/borderline EOL Chromebook on eBay for peanuts to run Chrome OS Flex or similar software.
из
I think my Dell Chromebook is administrative locked to a school. I had bought this laptop second hand it looked brand new and it came with the backpack I tried to turn it on but couldn't and it's been sitting on my shelf for a while until I made that last post and it's been sitting on my desk ever since I tried the escape refresh and power button combo and the power wash combo but nothing worked and a press control d enter control the enter. I had read another article that said that you enter control escape refresh and power button when your device is turned off and then press control the enter control the enter and then remove a write protection screw? so I took the back off my laptop and there's a spot missing where a screw would have gone that was surrounded by copper. do I say oh?
из
Добавить комментарий
1 ответ
Выбранное решение
You're thinking of going into developer mode, disabling OS verification, and running custom builds of ChromeOS. ChromeOS doesn't have Android-style root function. Depending on how you got it (a lot of people get these used), you need to check for that, as any good sysadmin who didn't get their IT credentials from the school of AI disables the developer mode terminal to prevent kids from hacking these things.
To do this, you will need to enter developer mode and disable OS verification by pressing Esc+Refresh. Then, press the power button while holding these keys. Note that this action does wipe the Chromebook for security, but since these are cloud-based, it's not a significant issue unless you use local storage. The other catch is that you will always need to press Ctrl+D to boot it once it's disabled to keep it "unlocked". IF you press the spacebar, it relocks it.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
из
Добавьте свой ответ
Anthony буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 24
За всё время: 103
