Why is my 2008 Cobalt LS not starting
I turn the key and I get nothing. It doesn't do it all the time but it does it frequently. Replaced the starter and solenoid, checked connections at the starter, changed relays around, changed ignition switch, and even tried to bypass all that and put in a start button (that worked when it was installed but now it doesn't) it really has me stumped. Does anyone have any other suggestions for this problem?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
Hi @joevenanzio
Do the appropriate instrument panel lights turn on when you operate the ignition key?
Here's the start circuit wiring diagram that may help you to find out why it's not cranking.
(click on image)
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Thanks for the diagram
из
Добавьте свой ответ
Joe Venanzio буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 86
