Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Corrosion on female end of MagSafe?
Hi everyone-
It would appear that after a long time of just answering questions it's my turn to ask a question.
Well so I've noticed that now the female end of the MagSafe connector on my MacBook looks like it has corrosion (or something else) there is discoloration and it looks like the port is "gunked up" or dirty somehow. What I want to no is if anyone can confirm that this is corrosion and/or explain how to clean it. I've heard simple rubbing alcohol and a paper towel will work, but I'm not sure.
I've attached a picture to show the issue.
Thanks for any help whatsoever!
Это хороший вопрос?
Счет 2
1 Комментарий
Oh and I should add- it charges just fine.
из
Добавить комментарий
2 Ответов
Выбранное решение
Try contact cleaner and a toothbrush or a stiff solder brush. Ralph
Был ли этот ответ полезен?
Счет 2
6 Комментариев:
So just hydrogen peroxide in general?
из
I'm not sure about that product==I always use electronic contact cleaner. You can get it at Radio Shack. Ralph
из
Do you mean electronic contact cleaner or contacts cleaner? If you mean the former then I'm not sure, but contacts cleaner is generally something along the lines of .02 H2O2
из
Electronic contact cleaner. Ralph
из
Looked it up-- part number 64-4345 Precision Electronics Cleaner. Ralph
из
Показать ещё 1 комментарий
I have a MacBook that looks just like that- I tried cleaning it with alcohol, but it didn't really work. To be honest, I think it's just discoloration from the magnet rubbing. It doesn't seem to be detrimental at all, so I just left mine alone.
Счет 0
1 Комментарий:
I'm worried about build-up over time though, and I don't think it's discoloration.
из
Добавьте свой ответ
rab777hp буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 20
За всё время: 4,026
