A few questions and some things to check:
- What engine do you have and how well maintained is it?
- Check the oil level & quality as well as the coolant level & quality.
- Can you try and locate the basic area that the noise is coming from? Top, middle or bottom? Left side, right side, front or back? Use a mechanic's stethoscope to listen, or if you don't have one, a long handled screwdriver with your ear pressed against the handle and the tip held at different points around the engine.
Top end noises can be valve train, valve springs, rocker arms or hydraulic lash adjusters.
Middle engine noises can be piston slap or wrist pins.
Bottom noises can be bearings, connecting rods or the crankshaft.
Front noises could be accessories, belts, water pump, or timing chain.
Rear noises could be flex plate to transmission.
Hope this helps,
BILL
Был ли этот ответ полезен?
Проголосовали
Отменить
Счет
4
Отмена
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
5 Комментариев
jswife20, which Camry is it? what engine size and what transmission do you have? Why do you think it is a stuck valve or rocker? What does your exhaust smoke look like and what do your plugs look like?
из oldturkey03
Open the hood and let the mechanic out!
из mayer
My wife "Likes" the mechanic answer. :-)
из HemiBill
So what was your problem I have a terrible knock sounds like it's coming right out of the front around the exhaust manifold but it's not a leaky manifold it's a definite metal-on-metal knock
из Chris Krause
pftt, fix the engine...it has nothing to do with higher octane, anything higher and the computer will go nuts and the car will not run properly because the 02 sensors will be causing hesitation...
this issue usually happens due to the typical oil leak in the camshaft seal after the car was ran with a low oil level causing the engine to get a bent rod.
из Michael D
