battery replacement instructions / guide
I need to replace the battery on my ipod touch 4th generation.I understand that the battery is available from Ifixit.
Do I get the replacement instructions with my order?Or can I find disassembly instructions online please.
Any link to the disssembly guide is higly appreciated.
thanks
vahid
Это хороший вопрос?
Счет -1
4 Комментариев
Thank you for your reply.
Do I need to use new adhesive once I have change the battery?
из
No, you will not. Just align the battery so that the ribbon cable is straight.
из
So ,after I have changed the battery , I'll just put everything back togeter and no new adhesive.The existing adhesive will work again no heating required.right?
из
No, you will need either new adhesive or some super glue.
из
Добавить комментарий
1 ответ
Выбранное решение
This will provide you with the guide to tear down the iPod until you get to the battery: iPod Touch 4th Generation Headphone Jack Replacement
Unfortunately, they do not have a direct guide to replace the Battery, this specific one is for replacing the Headphone Jack.
Best of Luck,
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Vahid буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 14
За всё время: 697
