Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1500вопросов Показать все
Sudden battery power drops with new battery
Hi,
I bought a new battery from iFixit to replace my fast draining old battery.
The new battery discharges much much more quickly but mostly it has very sudden power drops. For instance when the screen is off and I am using it to listen to music, it may drop 30% throughout the course of ten minutes.
The power drops even when charging it. If I charge it from off/red battery splash screen and when it gains enough charge to boot the phone, I've seen it immediately switch to the shutdown spinner during the apple boot logo when the power drop happens, and then return to the red battery splash picture.
Would it be possible that I made some common mistakes while replacing the battery and is there anything I should look for or check for?
Thanks
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
It could be that you have the wrong type of battery in the iPhone. Check the frequency and type of battery with the original battery. Try and find a exact replacement to install into your iPhone.
Also, make sure your mainboard is installed all the way, as a bad battery connection to the mainboard can cause problems.
Best of Luck,
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
michael будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 497
