Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203вопросов Показать все
Why my MacBook can not sleep?
When i close the lid, after 2 seconds the MacBook shuts down itself. Then when i open the lid, nothing happens. So i push the power button and i got a grey screen, then black screen, then the starting sound and finally a normal (??) boot. What can be?
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
When the battery is dead and the Book is put to sleep and the lid closed it will shut down. Go to Coconut battery and download and run the program. http://www.coconut-flavour.com/coconutba...
Tell us the battery status.
Был ли этот ответ полезен?
Оценка 1
6 Комментариев:
Ok here we go:
Current Battery Charge: 1810 mAh
Maximum Battery Charge: 4929 mAh
36%
_
Current Battery Capacity: 4929 mAh
Original Battery Capacity: 5020 mAh
98%
Add Info:
Loadcycles: 539
Age of my Mac: 17 Months
Charger connected: No
Battery is charging: No
But remember, i got this problem with or without the power adapter.
Thanks for your patience :)
из
It's having a little problem finding the system folder. Insert the System Installation disk and start up holding down the "C" key. On the third screen a pull down menu will appear. Go to Utilities - Disk Utilities and verify the disk then run the disk repair.
из
Still got the same problem :(
This mac came originally with 10.5.2, and now im running the 10.6.2, should I downgrade the system and upgrade again?
из
Or a logic board issue probably?
из
I have found almost nothing on this issue. http://forums.macosxhints.com/showthread...
The one fix I did see that worked was a clean install of the system. It's worth a try.
из
Показать 1 больше комментариев
I would try resetting the PRAM, and then SMC before moving on to hardware issues ...
check this out for PRAM ... http://support.apple.com/kb/HT1379
check this out for SMC ... http://support.apple.com/kb/HT3964
Let's see how that works to start ...
Оценка 0
1 Комментарий:
Still got the same problem :( Thanks a lot, anyway :)
из
Добавьте свой ответ
Eduardo Xavier Manfredini будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 1,133
