An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
What SSD sled do I need?
My macbook died and I have the SSD with my data. I am trying to buy an enclosure so I can extract the files.
Samsung M.2 NVMe SSD (PCIe), 128 GB, 2280 form factor
I bought two incorrect items already (External M.2 SSD NVMe Enclosure × 1)
What do I need to buy for this specific item?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
@margaretwhedon It might help if you let us know what exact Apple 'macbook" this comes out off. Apple used SSD’s that use proprietary connections and are not M.2 compliant!
If anything, check the ones on here as well as this one
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
MacBook Air (13-inch, 2017), Apple Model Number: A1466, Model Identifier: MacBookAir7,2, Serial Number: C02W92BJJ1WK, Purchase Date: April 26, 2018
Thanks for your suggestions! The first one looks exactly like what the folks at Apple used to read it; unfortunately it is sold out. I'll look into the second option!
из
@margaretwhedon 2nd option should work for this SSD as well. Best of luck to you and let us know how it works out.
из
Добавьте свой ответ
margaret whedon буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 15
За последние 7 дней: 15
За последние 30 дней: 15
За всё время: 15
