Repair, disassembly, and troubleshooting information for the Moto G Power 5G, a Motorola smartphone released in 2024. Identified by model number XT2415.
Possible Battery Charging Troubles
My phone would charge like normal, but then the eat away at the battery charge, and even shut off at random times, specifically around the 75%-65% area
Sometimes it would even read as zero percent, even though it's nowhere NEAR that; I've also noticed that the back has a noticeable bulge in it. Does this mean something is wrong with the battery itself?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@tonypitts all of what you are describing, including "the back has a noticeable bulge in it" makes it sound like you have a bad battery. It might even be possible that the battery is swollen to the point of putting pressure on the case. You do want to go ahead and replace it as soon a possible before it does more permanent damage.
To work on your phone us the Moto G Power 5G XT2415 Level 2 Repair Manual that you can download from this page under the Documents Header.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Tony Pitts буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 34
За всё время: 34
