Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597вопросов Показать все
Can you replace the HDD with SSD in the 2012 mac pro
I have just bought the 2.6ghz version of the macbook pro with a 750GB HDD and i was wondering if it is possible to replace the HDD with an aftermarket SSD preferably 250GB to 500GB. I know it is possible to remove the superdrive and put in a second SSD but i use the superdrive quite often.
Это хороший вопрос?
Оценка 0
1 Комментарий
The title says mac pro but the question is about macbook pro, please note that there is a mac pro unit which is totally different from macbook pro. Please clear up this ambiguity if possible.
из
Добавить комментарий
1 ответ
Выбранное решение
Yes, it is very easy to install an SSD. Most 2.5" SSD drives will fit and work in your MacBook Pro. You can buy and one of these SSD drives from this link:
http://eshop.macsales.com/shop/SSD/2.5
Some are upgrade kits and others are external dries so make sure you are getting a SSD and not and external drive. This guide will work for your device:
MacBook Pro 15" Unibody Late 2011 Hard Drive Replacement
I do not think that you will need pentalobe screws so you should check the screws on the bottom of your laptop.
Hope this Helps.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Just use the screws from the magnetic HDD you are replacing, because the SSD drive will need to sit inside the MacBooks HDD chassis mount.
из
Добавьте свой ответ
Craig Blake будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 6
За последние 30 дней: 10
За всё время: 11,287
