Not charging after water damage
My Iphone got wet. I dried it using all of the tips and tricks but it will not charge. I have disassembled it using the guides and cleaned everything appropriately. It still doesn't charge. When I plug it to the wall charger it will come on but it will not stay on long. When I use the USB charger and a computer I get the apple symbol for a few seconds the it shuts off again. I replaced the battery and everything worked fine until the new battery drained. Now I'm back to square one. What else can I do to repair the charging issue?
Это хороший вопрос?
3 Комментариев
OK. I just removed the battery and plugged it to the USB on my computer. It still get the apple symbol for a few seconds and then it goes off. So I could use the phone when the battery was charged but the phone still will not come on with direct power to the charge port.
из Chad
I have figured out that the two outter pins on my battery connector are shorted. Any ideas on where to look to repair the short?
из Chad
On your battery, or on your battery connectors? How do you figured out that they are shorted?
из oldturkey03
