Компьютеры, которые, как правило, не включают встроенный дисплей и предназначены для стационарного использования.
32GB Ram Full why
how can I solve this
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@almaunislamt894 this does not necessarily refer to the storage space but it could mean that your computer may not have enough virtual memory. See if you can adjust the virtual memory manually. Search for the system in the taskbar and open it, click Advanced -- Settings (in Performance) -- Advanced, and then click Change. You also want to restart the Explorer.exe No reason to restart your computer but just run the file. Let us know what happens.
Also, this seem to be a common Windows error, so we will need to know which version Windows you are running.
I would also recommend that you remove the less used files as well as the programs that you are not using, from your computer. These can a. use valuable storage space and b. may use additional memory resources. I would suggest that you use the 32GB drive for your OS only and get another dive, either internal or external that you can use as your storage drive.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Al Maun Islam Tonmoy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 23
За всё время: 23
