Repair guides and support for home heating, ventilation, and air conditioning system repair.
How to turn off heat
Update (05/15/26) ===
How to turn off the heat
Update (05/15/26)
Update (05/15/26)
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Under normal operation, the thermostat controls heat. Presuming 24vac power is there, the t-stat and electrically powered zone valves are operational. The first image of a TACO zone valve is operated by thermostat. The metal lever attaches to the valve for manual operation if t-stat (24vac) power is lost; left/closed/no hot water circulation to baseboard heating, right/open valve/hot water circulation. The circulator pump is also controlled by the t-stat; on for heat, off to stop hot water circulation.
Home hvac systems are not diy friendly. Perhaps a professional plumber should be called to investigate this peculiar problem.
I'm not familiar with the bottom image, also a valve.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Peggy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 52
За всё время: 52
