Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Вопросов 20 Показать все
ipad 2 disabled connect to itunes
Tried DFU mode and tried to restore on 3 different computers running windows XP Pro & windows 7 Home Premium and itunes. ipad 2 not recognized, I have a second ipad 2 works fine on all the above.
any suggestions.
Thanks
Это хороший вопрос?
Оценка 3
Добавить комментарий
Ответов (1)
Выбранное решение
Have you tried bypassing the "ipad is disabled" screen? There is an easy way to do it with the first ipad and I have heard that it now works with the ipad 2 by selecting ipad from the drop down menu in Gecko. The instructions can be found here.
Был ли этот ответ полезен?
Оценка 4
1 Комментарий:
I try to click the found here link and it tells me forbidden cannot connect to this
What do I do I have one I pad stuck in activation mode and one that just says connect to iTunes but when I do it doesn't read that its connected or when it does says restore failed why
из
Добавьте свой ответ
Larry будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 10,308
