Sorry to say you need to install 10.7.4 as the newer hardware requires it.
You don't need any additional OS software to get this working. The newer Macs have a hidden partition with the recovery files to either restore your HD or install other disks with the OS.
Not sure I fully understand your process you used in prepping the SSD. Here's the steps you need to do.
First you need to install the SSD into an external case connecting to your system via USB or Firewire (better).
With your working HD still in your system and you have applied all of the OS updates from Apple to your system. Run the OS install program make sure to select the external drive at that point you should be all set getting the OS onto the SSD. Before swapping out your drives switch which drive to boot from and make sure it's the one booting. At that point swap out the drives.
Two things to remember your now running from a SSD that does not have a hidden partition so you must not loose or alter your system HD as you would not have any way to recover the OS if you do.
You might want to create a bootable CD or flash drive with the OS and recovery files on it before you remove the HD from your system just to give your self a second option (you never know!). Apple has a utility to copy over the needed files from the hidden partition. Again, make sure your created CD or flash drive works (boots & can install the OS onto a CD or flash drive).
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
