What do I do with a PS3 with no power?
Well, first, I opened my ps3 and tried to see why the fan goes so high and fast. When I took off the heatsink/fan, the GPU plate came off too so I put new thermal grease/paste/arctic silver ceramique on it and the 5 little ones on the GPU after the plate came off and put the plate back on it. I also cleaned with a cotton swab dipped in alcohol around the top of the GPU and I think I might have gotten alcohol on the capacitors of the GPU but, I dried it all out carefully. When I put everything back together, I got no power at all. My PS3 is dead. It will not turn on no matter what. What do I do? :(
Это хороший вопрос?
6 Комментариев
Have you tried to check your power supply to make sure it is working?
из oldturkey03
Actually, no....I have no idea how to do that. Doesn't it need to be connected to the PS3 to find out if it works?
из Majin Riddler
It is all back together? Check on here where your power supply is PlayStation 3 Power Supply Replacement Do you own a multimeter and have some basic knowledge how to see if it has any power?
из oldturkey03
No. I have no ohm meter or multimeter. I have never done that before.
из Majin Riddler
i did the same thing but my PS3 wotn turn on,
i even gave it 12 volts from my own power supply and nothing, no light no nothing.
Help
из Jose
Показать 1 больше комментариев
