Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794вопросов Показать все
My MacBook doesn't cool properly
My macbook pro isn't cooling properly anymore and also it is making an awful lot of noise, my dad says it's because there is dust inside it. I don't dare to open it up because I'm scared that I won't be able to put it back together. my question is: Is it safe to open the back of my computer to remove possible dust from the fan?
I need help.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Hello Douwe,
Don't be scared of opening up your computer. As long as you have the right tools, you should have no problem cleaning up any dust inside the computer. Here is a guide on how remove the fan, if that is the route you should choose.
It is also likely that the thermal paste should be reapplied. After a while, the thermal paste on the processors can go sour, causing symptoms just like you described. This guide will show you how to get the heat sinks off.
MacBook Pro 13" Unibody Mid 2010 Fan Изображение
Инструкция
MacBook Pro 13" Unibody Mid 2010 Fan Replacement
Сложность:
Модерировать
10 - 25 minutes
MacBook Pro 13" Unibody Mid 2010 Heat Sink Изображение
Инструкция
MacBook Pro 13" Unibody Mid 2010 Heat Sink Replacement
Сложность:
Сложно
1 - 2 hours
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Douwe Vanneste будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 1,045
