iSight light is always on
The green "camera is on" iSight light to the right of the iSight is perpetually on! I know that the camera is not actually on (the cable is not even connected), but it is still unnerving. Any ideas?
Это хороший вопрос?
Это хороший вопрос?
You should try disconnecting the cable to the light (if possible) and reconnecting it to see if that helps
Был ли этот ответ полезен?
Well, this didn't fix the problem, but it gave me the motivation to open the machine and disconnect the cables. The light is definitively off now! Thanks!
I can see you!
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 2,534
1 Комментарий
the fact that the camera is disconnected does not stop the rest of the circuitry to switch off / on. So is the camera actually on when you connect the cable?
из Spikey2
