iSight light is always on
The green "camera is on" iSight light to the right of the iSight is perpetually on! I know that the camera is not actually on (the cable is not even connected), but it is still unnerving. Any ideas?
Это хороший вопрос?
Счет 1
1 Комментарий
the fact that the camera is disconnected does not stop the rest of the circuitry to switch off / on. So is the camera actually on when you connect the cable?
из
Добавить комментарий
1 ответ
Выбранное решение
You should try disconnecting the cable to the light (if possible) and reconnecting it to see if that helps
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Well, this didn't fix the problem, but it gave me the motivation to open the machine and disconnect the cables. The light is definitively off now! Thanks!
из
I can see you!
из
Добавьте свой ответ
Ben Eisenman буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 21
За всё время: 2,850
