CDMA версия четвертого поколения iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. 16 или 32 ГБ памяти / Модель A1349 / Cовместимость с CDMA.
295вопросов Показать все
Where do I clean if I got finger oil on my parts?
I had my iPhone into a shop for repairing when my power button failed. After I got it back, I have very bad bluetooth reception and almost non-existent WiFi. I remember that the shop did not use gloves. I took it back there and they are denying all responsibility.
So I assume that there's probably some finger oil on various parts and I've seen all of the suggestions on here about cleaning "all contacts" with a degreaser or Windex. But I don't know what "all contacts" are. Can someone help me out and point them out?
Это хороший вопрос?
Оценка 1
2 Комментариев
Thanks, Brett. I didn't check this until after I left work so I will try on Monday when I have access to my Pentalobe screwdriver.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hey Snowdog,
This is a pretty common problem, and you're correct about the finger oil causing bluetooth to fail.
There are a couple places that you should clean the contacts before re-assembly. While many of connectors in the iPhone use plug-and-socket connections, many just use spring pressure contacts. These pressure contacts are those which you should clean off. Here are a few:
Use some isopropyl alcohol or some Windex on a Q-tip or microfiber cloth, and you should be golden.
Good luck, and let us know how it turns out.
iPhone 4 Power & Lock Button Изображение
Инструкция
iPhone 4 Power & Lock Button Replacement
Сложность:
Сложно
15 - 30 minutes
iPhone 4 Verizon Power Button Изображение
Инструкция
iPhone 4 Verizon Power Button Replacement
Сложность:
Сложно
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
snowdog850 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 1,633
