YLOD repair then relapse
Used YLOD kit and ended up with 4 extra 9mm screws. Worked fine then re-YLODed. Used guide again, replaced thermal paste, put back together, somewhat wonky looking, with 4 9mm screws left. Unit goes to instant YLOD when started. What do I do? Can this be fixed?
Это хороший вопрос?
Оценка -1
1 Комментарий
I actually used the guide to do this, twice in fact. Will I need to take it apart, remove the thermal paste (which there is a fair amount of), and redo? Also, could I use the heat gun from the kit to heat the board if that would help? The front of the PS3 doesn't look put back together right, and I am still have 4 "extra" 9mm screws, is there a reassemble guide? Thanks for the help.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Perhaps you should try actually reflowing/reballing the CPU, if you haven't yet.
Google it :P
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I don't think a heat gun is the best way to reflow something anymore, after using one on several things. I think a micro torch/ small propane torch would work better, since its easier to control.
The heat gun's heat spreads out too much, usually, and melts plastic things.
Anyway, that's just my opinion
из
theunknown, I would suggest you start off by using this guide. Follow it as described, it does have a high rate of success. Most reasons why it may fail is that people are not aggressive enough for the reflow. Just like anything else, this may only be a temporary fix. Only a complete reflow will be more permanent. Hope this helps, good luck.
Оценка 1
Добавьте свой ответ
theunknown74 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 720
