Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
How do I affix screen?
I successfully replaced the screen on my iPod Nano 6th Gen. However, I am not sure how to affix the screen to the device. Is there a particular adhesive that works best?
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Выбранное решение
I've tried both methods on the nano 6G. super glue is a great bond but nearly impossible to open again. 3M double sided tape works best - strong bond, yet can still be opened in the future.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Thanks..will give double sided tape a try.
из
Sadly the guide neglects to mention you will need new tape to fully repair the 6G, however, here's the URL for the 3M double sided tape you should use to affix the screen to the case -
[связанный продукт отсутствует или отключен: IF145-283-2]
It's more then you will need to finish the repair, however, this tape has a number of uses and is a welcome addition to my parts box.
из
good question, i use Two sided tape.
works well for me but it is weaker then the adhesive that originally was on the screen.
Счет 0
1 Комментарий:
Thanks..I will take a look at that option. I am also considering superglue as an option.
из
Добавьте свой ответ
chris буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 3,306
