Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203вопросов Показать все
Вопрос закрыт
Ethernet port seems not to be working..
Couple days ago my internet stop working. I use a ethernet cable to get as much internet speed as i can. I replaced the ethernet cable and still cant get internet unless i use wireless. I know my router works i tired a different Mac. I did a lot of looking around for info but no such luck. Can anyone help. I pay alot for high internet speed that i need for work and cant use it because of wireless.
Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
5 Ответов
Выбранное решение
First check under System Preferences:Network that you didn't delete or disable your Ethernet service. Next under Applications->Utilities->System Profiler:Hardware-Ethernet cards ensure your device shows up. If those are copacetic look at the ends of your Ethernet cable (connector) to ensure it's locking tang is (locking in).
If this answer was helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Check where you said and it shows that ethernet card connected. Looked at the connector of my cable and it looks good and it is locking in. Also check the port its self, blew it out and check the copper connectors and everything looks right. Could the port itself be disconnected inside the Mac.
из
A workaround is to get a USB Ethernet Dongle... you can't DIY repair a port connection to a logic board.
из
I am facing a similar issue here with my mid-2009 13.3" Macbook Pro.
All of a sudden, the Ethernet port stopped being responsive. I checked the Ethernet card and everything seems to be fine. Also, the port itself looks clean from the outside. I wouldn't mind replacing it for a new one by myself, but the ifixit guides do not have a tutorial on that (maybe it's not replaceable?).
Please help! :-/
Оценка 0
1 Комментарий:
Not as a DIY - Apple or a computer repair shop would have the tools & skills. Soldering MLBs is not like soldering a patch cord.
из
troubleshooted this and i dont have an ethernet card installed now????
This computer does not appear to have any PCI Ethernet cards installed.
that was the exact message. what can i do?
Оценка 0
1 Комментарий:
doug02496 - For future reference you posted a Question in the place where only Answers belong. Please use the add comment link to the appropriate Answer, Question or create your own original Question. In it remember to include the exact laptop, and OS and some history... when did this first occur? have you been inside the box? did it get wet or dropped? 'Help us help you. The more complete the description of your problem is the more assistance we can provide, and, the sooner we can provide it..
из
I got exactly the same thing.
"This computer does not appear to have any PCI Ethernet cards installed."
MacBook4,1
Intel Core 2 Duo
2.1 GHz
3 GB
800 MHz
MB41.00C1.B00
SMC: 1.31f1
Serial Number: W88185E70P0
UUID Hardware: FD5EDA93-4B73-5D2C-8744-DF730573A8D8
Оценка 0
Apple is a big bullshit because they should standardize the modem adapter to accept every windows service as microsoft does... fcking tired of that :S
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 11,577
