ASUS TUF Gaming F15 FX506L Back Cover Replacement
Выберете то, что вам нужно
  1. ASUS TUF Gaming F15 FX506L Back Cover Replacement, Unfasten the back cover: шаг 1, изображение 1 из 2 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Unfasten the back cover: шаг 1, изображение 2 из 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips screwdriver to remove the 10 screws securing the back cover:
    • Seven 11.6 mm screws
    • Two 14.6 mm screws
    • One 6 mm screw
    • Use a Phillips screwdriver to loosen the captive screw.
    • Loosening this captive screw will pop up and separate the bottom-right corner of the back cover from the chassis.
    • During reassembly, tighten the captive screw before the rest of the screws.
  2. ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the clips: шаг 2, изображение 1 из 2 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the clips: шаг 2, изображение 2 из 2
    • Insert an opening pick between the bottom-right corner of the back cover and the chassis, near the captive screw.
    • Pry up to release the clips securing the back cover.
    • You'll hear a click whenever a clip is released.
  3. ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the remaining clips: шаг 3, изображение 1 из 3 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the remaining clips: шаг 3, изображение 2 из 3 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the remaining clips: шаг 3, изображение 3 из 3
    • Insert your opening pick again between the top-left corner of the back cover and the chassis.
    • Insert the pick at a steep angle. Pry up to release the remaining clips securing the back cover.
  4. ASUS TUF Gaming F15 FX506L Back Cover Replacement, Remove the back cover: шаг 4, изображение 1 из 3 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Remove the back cover: шаг 4, изображение 2 из 3 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Remove the back cover: шаг 4, изображение 3 из 3
    • Lift the back cover off the chassis and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our ASUS TUF laptop answers community for help.
3 участников успешно повторили данное руководство.
Clay Eickemeyer
Участник с: 09/19/22
67 193 Репутация
Автор 453 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 392 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 67
За последние 30 дней: 319
За всё время: 6,702
