Acer One 10 S1003-114M Battery Replacement
Выберете то, что вам нужно
  1. Acer One 10 S1003-114M Battery Replacement, Battery: шаг 1, изображение 1 из 2 Acer One 10 S1003-114M Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Make sure the device is turned off and disconnected from any power source.
    • To disconnect the tablet from the keyboard attachment, open the laptop and lift the tablet component up from the keyboard dock.
    Nice guide, but warning!
    If doing step 5, be very carefull. Guide says "unscrew the two 2mm screws at the top right of the battery", but not explains, what you are doing. So here is explanation: doing so you release the metal bridge, which is fixing the battery connector. After you unscrew the second screw, the bridge is not fixed in any way, and can sudenly fall on the circuit board.
    I suggest to hold on this part and remove it carefully, because battery connector is still connected, so all components are powered. The metal part can cause a short circuit and demage motherboard. This is exactly what happened to me. Unfortunately, the manufacturer has not published service manual with a schematic and layout, so the only (really expensive) solution is to replace the motherboard. So watch out!!
    Anthony - Ответить
  2. Acer One 10 S1003-114M Battery Replacement: шаг 2, изображение 1 из 3 Acer One 10 S1003-114M Battery Replacement: шаг 2, изображение 2 из 3 Acer One 10 S1003-114M Battery Replacement: шаг 2, изображение 3 из 3
    • While handling the device, make sure to avoid pushing the power button. Device must remain powered off.
    • Metal spudgers and similar prying tools can damage internal components like the motherboard. It is ideal to use a regular black nylon spudger or a plastic opening tool, but for this device the metal jimmy and spudger were the only tools that worked.
    • Starting from the corner of the tablet, use a jimmy to create a gap between the screen and the back covering.
    • Insert a metal spudger in the gap that you created with the Jimmy.
    • Slowly maneuver the metal spudger along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
  3. Acer One 10 S1003-114M Battery Replacement: шаг 3, изображение 1 из 2 Acer One 10 S1003-114M Battery Replacement: шаг 3, изображение 2 из 2
    • Using your hands, peel off the Polyimide tape (yellow tape).
  4. Acer One 10 S1003-114M Battery Replacement: шаг 4, изображение 1 из 3 Acer One 10 S1003-114M Battery Replacement: шаг 4, изображение 2 из 3 Acer One 10 S1003-114M Battery Replacement: шаг 4, изображение 3 из 3
    • Using the Phillips #00 screwdriver, unscrew the two 2mm screws at the bottom of the tablet and open the ZIF latch.
    • Gently remove the gold ribbon cable covering the battery and set it aside.
    for removing the upper-end of the ribbon, one have to lift a little bit the connector, then it is very easy to extract the upper side of the ribbon
    trasferimento trasferimento - Ответить
    In step 4, the instructions say: "unscrew the two 2mm screws at the bottom of the tablet and open the ZIF latch". If you do it as described, you risk damaging the motherboard. Why?
    When you unscrew the screws, you release the metal bridge, fixing the connector. Although this part will remain glued to the battery cable, it is not fixed in any way, so it can fall on the circuit board at any time. But until you disconnect the battery from the PCB, the components on the board are powered and the metal part can cause a short circuit and irreversibly destroy the motherboard.
    This is exactly what happened to me. Unfortunately, the manufacturer has not published service documentation with a diagram and layout of components, so the only solution (and expensive one) is to replace the motherboard. So I recommend holding the metal bridge while loosening the screws, carefully remove it and only then handle the ZIF connector. It is even safer to cover the PCB around the connector with insulating material.
    Anthony - Ответить
  5. Acer One 10 S1003-114M Battery Replacement: шаг 5, изображение 1 из 2 Acer One 10 S1003-114M Battery Replacement: шаг 5, изображение 2 из 2
    • Using the Phillips #00 screwdriver, unscrew the two 2mm screws at the top right of the battery.
  6. Acer One 10 S1003-114M Battery Replacement: шаг 6, изображение 1 из 2 Acer One 10 S1003-114M Battery Replacement: шаг 6, изображение 2 из 2
    • Peel the three shiny black stickers from the battery (top left, bottom right, and bottom left), but keep them attached to the motherboard.
  7. Acer One 10 S1003-114M Battery Replacement: шаг 7, изображение 1 из 2 Acer One 10 S1003-114M Battery Replacement: шаг 7, изображение 2 из 2
    • Battery is adhered to the tablet.
    • Avoid putting pressure on the glass while separating the battery from the screen.
    • Use the spudger to separate the battery from glue that holds the battery to the screen. Carefully pry the battery from the tablet.
  8. Acer One 10 S1003-114M Battery Replacement: шаг 8, изображение 1 из 1
    • Remove the battery from the device.
    How l can get one battery like this one
    dr.m.fayaad - Ответить
Заключение
5 человек успешно провели ремонт по этому руководству.
Rachel Harrison
Участник с: 04/09/18
596 Репутация
Автор 4 руководств
Команду
Eastern Washington University, Team S1-G5, Carnegie Spring 2018 Участник Eastern Washington University, Team S1-G5, Carnegie Spring 2018
EWU-CARNEGIE-S18S1G5
4 членов
Автор 6 руководств
1Комментарий к руководству
Where can I find the battery for this?
Ronny Merino Gonzalez - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 28
За последние 30 дней: 98
За всё время: 7,298
