Amazon Kindle 8 Battery Replacement
Выберете то, что вам нужно
  1. Amazon Kindle 8 Battery Replacement, Front Cover: шаг 1, изображение 1 из 2 Amazon Kindle 8 Battery Replacement, Front Cover: шаг 1, изображение 2 из 2
    • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
    • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
    • Keep even pressure to avoid any cracks.
    • Lift front cover once all clips are disengaged.
    • Lift the screen gently so that it is not cracked.
  2. Amazon Kindle 8 Battery Replacement: шаг 2, изображение 1 из 2 Amazon Kindle 8 Battery Replacement: шаг 2, изображение 2 из 2
    • Insert the spudger between the inner cover and the screen.
    • Gently work your way around to loosen the front cover.
    • Carefully lift the front cover from the device.
  3. Amazon Kindle 8 Battery Replacement, Motherboard: шаг 3, изображение 1 из 2 Amazon Kindle 8 Battery Replacement, Motherboard: шаг 3, изображение 2 из 2
    • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
  4. Amazon Kindle 8 Battery Replacement: шаг 4, изображение 1 из 2 Amazon Kindle 8 Battery Replacement: шаг 4, изображение 2 из 2
    • Lift the screen and motherboard from the back cover.
  5. Amazon Kindle 8 Battery Replacement, Battery: шаг 5, изображение 1 из 1
    • Pinch the clips on the battery and disconnect the battery connector from its socket.
  6. Amazon Kindle 8 Battery Replacement: шаг 6, изображение 1 из 1
    • Insert the halberd spudger between the motherboard and battery.
    • Take care not to bend, twist, or puncture the battery.
    • Slowly move the spudger around the battery and pry it off.
    • The battery is glued in place, so don't be afraid to use some moderate force.
Заключение
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Luke
Участник с: 09/25/24
420 Репутация
Автор 5 руководств
Команда
University of Memphis, Team 1-5, Sneed Fall 2024 Участник University of Memphis, Team 1-5, Sneed Fall 2024
UM-SNEED-F24S1G5
4 членов
Автор 8 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 24
За последние 7 дней: 109
За последние 30 дней: 388
За всё время: 2,564
