Введение
This is a step by step guide on how to replace the charging port in the Anker SoundCore 2 bluetooth speaker. There are a few reasons on why you may need to replace the charging port, including if your speaker will no longer charge or no longer achieve a full charge. Take a look at the troubleshooting page to see if you need to replace the charging port or not. For this guide, you will need a screwdriver and a soldering tool.
Выберете то, что вам нужно
Insert a spudger between the front panel and the body of the speaker.
Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
Use your hand to remove the speakers.
Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
Desolder the charging port from the motherboard and solder a new one on.
5 участников успешно повторили данное руководство.
5 Комментариев
Hello please what's the model of the ESD4 and C34 close to the charging port?
what's the micro usb port part number? I want to replace it but can't find info on it anywhere.
I use Anker OEM style replacement in my repair shop from eBay listing 254057783007
Perfect fit.
https://www.ebay.com/itm/254057783007
Good luck with the project
