Asus X553MA-BPD07051 Motherboard Replacement
Выберете то, что вам нужно
  1. Asus X553MA-BPD07051 Motherboard Replacement, Battery: шаг 1, изображение 1 из 2 Asus X553MA-BPD07051 Motherboard Replacement, Battery: шаг 1, изображение 2 из 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
  2. Asus X553MA-BPD07051 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
    • Do not lift the keyboard too high as the keyboard is connected to the motherboard by two ribbon connectors that must be detached.
  3. Asus X553MA-BPD07051 Motherboard Replacement: шаг 3, изображение 1 из 2 Asus X553MA-BPD07051 Motherboard Replacement: шаг 3, изображение 2 из 2
    • Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
    • Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
  4. Asus X553MA-BPD07051 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
    • Make sure that you do not remove the entire connector by applying too much force. Only the white plastic connector should be removed from the metal part on the motherboard.
  5. Asus X553MA-BPD07051 Motherboard Replacement: шаг 5, изображение 1 из 2 Asus X553MA-BPD07051 Motherboard Replacement: шаг 5, изображение 2 из 2
    • Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
  6. Asus X553MA-BPD07051 Motherboard Replacement: шаг 6, изображение 1 из 2 Asus X553MA-BPD07051 Motherboard Replacement: шаг 6, изображение 2 из 2
    • Lift the battery up and remove it completely from the laptop.
  7. Asus X553MA-BPD07051 Motherboard Replacement, Hard Drive: шаг 7, изображение 1 из 2 Asus X553MA-BPD07051 Motherboard Replacement, Hard Drive: шаг 7, изображение 2 из 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws that are securing the hard drive.
  8. Asus X553MA-BPD07051 Motherboard Replacement: шаг 8, изображение 1 из 2 Asus X553MA-BPD07051 Motherboard Replacement: шаг 8, изображение 2 из 2
    • Lift the hard drive up and pull it towards the screen so that it disconnects from the motherboard.
    • Use caution when disconnecting the hard drive from the motherboard, so that neither connector gets broken.
  9. Asus X553MA-BPD07051 Motherboard Replacement, Optical Drive: шаг 9, изображение 1 из 2 Asus X553MA-BPD07051 Motherboard Replacement, Optical Drive: шаг 9, изображение 2 из 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the one 6.0 mm screw holding in the optical drive.
  10. Asus X553MA-BPD07051 Motherboard Replacement: шаг 10, изображение 1 из 2 Asus X553MA-BPD07051 Motherboard Replacement: шаг 10, изображение 2 из 2
    • Gently slide the optical drive out from the motherboard.
  11. Asus X553MA-BPD07051 Motherboard Replacement, Motherboard: шаг 11, изображение 1 из 3 Asus X553MA-BPD07051 Motherboard Replacement, Motherboard: шаг 11, изображение 2 из 3 Asus X553MA-BPD07051 Motherboard Replacement, Motherboard: шаг 11, изображение 3 из 3
    • Remove the bundled cable connector that connects the fan to the motherboard using the plastic iFixit opening tool.
    • Remove the bundled cable connector that attaches the audio to the motherboard with the plastic iFixit opening tool.
  12. Asus X553MA-BPD07051 Motherboard Replacement: шаг 12, изображение 1 из 2 Asus X553MA-BPD07051 Motherboard Replacement: шаг 12, изображение 2 из 2
    • Lift the metal clip holding the ZIF connector ribbon down.
    • Pull the ribbon out from the connector, away from the motherboard.
  13. Asus X553MA-BPD07051 Motherboard Replacement: шаг 13, изображение 1 из 2 Asus X553MA-BPD07051 Motherboard Replacement: шаг 13, изображение 2 из 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the five 6.0 mm screws attaching the motherboard to the base of the laptop.
  14. Asus X553MA-BPD07051 Motherboard Replacement: шаг 14, изображение 1 из 1
    • Remove the tape from the motherboard.
  15. Asus X553MA-BPD07051 Motherboard Replacement: шаг 15, изображение 1 из 2 Asus X553MA-BPD07051 Motherboard Replacement: шаг 15, изображение 2 из 2
    • Lift the metal clips holding the ZIF connector down.
    • Push the gold metal connector away from the motherboard.
    • Be careful not to break the connector.
  16. Asus X553MA-BPD07051 Motherboard Replacement: шаг 16, изображение 1 из 2 Asus X553MA-BPD07051 Motherboard Replacement: шаг 16, изображение 2 из 2
    • Lift the coaxial connector from the wifi chip with the plastic iFixit opening tool.
  17. Asus X553MA-BPD07051 Motherboard Replacement: шаг 17, изображение 1 из 3 Asus X553MA-BPD07051 Motherboard Replacement: шаг 17, изображение 2 из 3 Asus X553MA-BPD07051 Motherboard Replacement: шаг 17, изображение 3 из 3
    • Lift the motherboard to remove it fully.
    • Do not pull too hard, the motherboard should come off easily once it has been separated from the base of the laptop.
Заключение
3 участников успешно повторили данное руководство.
Stephanie DeCarvalho
Участник с: 10/21/19
898 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team S1-G4, Botvin Fall 2019 Участник UMass Dartmouth, Team S1-G4, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G4
3 членов
Автор 5 руководств
5 Комментариев
Hi! Where the !&&* is the CMOS battery?
butch zvonko - Ответить
Hi, I’m sorry but I don’t have an image of the CMOS battery! It should be located on the motherboard though.
Stephanie DeCarvalho -
See my reply below. There isn’t one.
Gazza
gazza667 -
Hi, I think there is no CMOS battery on this motherboard. See https://vinafix.com/media/asus-x553ma.11....
I can vouch that there is NO CMOS battery on this laptop. I now own one from a friend who had it condemned by another ‘repair tech’. It turned out that the display connector was not secured properly. Anyway, having stripped it down completely, i decided to replace the CMOS battery before putting it back together & there isn’t one. On the underside of the board is an area with white plastic in the shape of a button battery. On reassembly i noticed the CMOS had lost the clock memory. Which i put down to disconnecting the battery. It must be powered when the battery is connected & not separately.
Gazza
gazza667 -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 34
За всё время: 2,354
