Введение
This repair guide will help you with the following:
- Install the left headphone cable
- Fix sound coming from the left headphone
Выберете то, что вам нужно
Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference How To Solder and Desolder Connections.
Untie the knot in the thick main cable.
Remove the main cable from the headphones by pulling it out.
Thread the replacement cable into the hole on the bottom of the headphones. Pull the cable all the way through.
“Thread the replacement cable into the hole on the bottom of the headphones“ what replacement cables?
Hey, read my comment on the bottom of the guide if it’s still relevant to you.
I have the same question, what replacement cable do I need?
Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference How To Solder and Desolder Connections.
3 человек успешно провели ремонт по этому руководству.
2 Комментариев
Not sure if it’s on purpose or not but on my A900Xs the cable is on the left headphone and so, the one on the right is the one with the tiny wire going through, I found that a 2 core wire is needed for this replacement, I only managed to find one that’s 1,4mm diameter and it seems to be a little thicker than what’s actually inside the headphones but I figured I’ll give it a try, anyways here’s the wire I found on AliExpress https://www.aliexpress.com/item/40004436...
