Beats Studio 2 Wireless Speaker Replacement
Выберете то, что вам нужно
  1. Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: шаг 1, изображение 1 из 2 Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: шаг 1, изображение 2 из 2
    • Insert a spudger between the plastic part of the left headphone and the ear cushion.
    • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
  2. Beats Studio 2 Wireless Speaker Replacement: шаг 2, изображение 1 из 3 Beats Studio 2 Wireless Speaker Replacement: шаг 2, изображение 2 из 3 Beats Studio 2 Wireless Speaker Replacement: шаг 2, изображение 3 из 3
    • Pull the rest of the cushion away from the adhesive with your hands.
  3. Beats Studio 2 Wireless Speaker Replacement, Speaker: шаг 3, изображение 1 из 2 Beats Studio 2 Wireless Speaker Replacement, Speaker: шаг 3, изображение 2 из 2
    • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
    • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
  4. Beats Studio 2 Wireless Speaker Replacement: шаг 4, изображение 1 из 1
    • Gently separate the speaker from the headphones.
    • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
  5. Beats Studio 2 Wireless Speaker Replacement: шаг 5, изображение 1 из 2 Beats Studio 2 Wireless Speaker Replacement: шаг 5, изображение 2 из 2
    • Gently pull the wire with rubber connectors off of the speaker.
  6. Beats Studio 2 Wireless Speaker Replacement: шаг 6, изображение 1 из 1
    • Use a soldering iron to desolder the two connections.
    • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
    • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
    • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
Заключение
After soldering the new speaker, reassemble your device by following the steps in reverse order.
3 участников успешно повторили данное руководство.
Mike Rosiello
Участник с: 03/20/23
313 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 5-3, Ramos Spring 2023 Участник UMass Dartmouth, Team 5-3, Ramos Spring 2023
UMASSD-RAMOS-S23S5G3
3 членов
Автор 4 руководств
Один комментарий
I didn't need to replace a speaker but just touch up the solder joints, this was a great guide! Thank you!
William Pryor - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 13
За последние 30 дней: 31
За всё время: 292
