Button Controller Board Replacement
Выберете то, что вам нужно
  1. Button Controller Board Replacement, Exterior Housing: шаг 1, изображение 1 из 3 Button Controller Board Replacement, Exterior Housing: шаг 1, изображение 2 из 3 Button Controller Board Replacement, Exterior Housing: шаг 1, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    iOpener
    $24.95
    • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
    • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
    • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
    Спросите у FixBot
  2. Button Controller Board Replacement, Lower Half Casing: шаг 2, изображение 1 из 3 Button Controller Board Replacement, Lower Half Casing: шаг 2, изображение 2 из 3 Button Controller Board Replacement, Lower Half Casing: шаг 2, изображение 3 из 3
    • Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
    • Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
    • Lift and remove the counterweight.
    Спросите у FixBot
  3. Button Controller Board Replacement: шаг 3, изображение 1 из 3 Button Controller Board Replacement: шаг 3, изображение 2 из 3 Button Controller Board Replacement: шаг 3, изображение 3 из 3
    • Lift and remove the plastic casing.
    • Note: It is best to lift the casing starting from the side without the protruding 3.5mm audio port and power port.
    • Reminder: During this process, a rubber cover will likely be dislodged. Make sure to re-seat this cover on the small pegs before putting the plastic casing back on.
    Спросите у FixBot
  4. Button Controller Board Replacement, Preliminary Main Board: шаг 4, изображение 1 из 2 Button Controller Board Replacement, Preliminary Main Board: шаг 4, изображение 2 из 2
    • Remove the two 9 mm screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
    Спросите у FixBot
  5. Button Controller Board Replacement: шаг 5, изображение 1 из 1
    • Peel away the black tape covering the red wires that connect to the PCB.
    Спросите у FixBot
  6. Button Controller Board Replacement: шаг 6, изображение 1 из 1
    • There is ribbon wiring under this PCB. Be careful not to damage it while removing the PCB.
    • Slowly lift the PCB away from the rest of the device
    • Remove the ribbon by first removing the brown insert piece from the connector on the button board
    • Pull the ribbon out of the connector on the button board by the blue tab.
    Спросите у FixBot
  7. Button Controller Board Replacement: шаг 7, изображение 1 из 1
    • Carefully disconnect the white 11-pin connector from the main board.
    • Pull firmly on the connector and use a screwdriver to pry it slightly if necessary.
    Спросите у FixBot
  8. Button Controller Board Replacement, Button Controller Board: шаг 8, изображение 1 из 2 Button Controller Board Replacement, Button Controller Board: шаг 8, изображение 2 из 2
    • Remove the four 6 mm screws that secure the button controller PCB to the rest of the device; you will need a Phillips #2 driver for this task.
    • Note: Since the main board is on top of this PCB, you may need to move the main board out of the way to access the screws.
    • Lift the PCB away from the rest of the device.
    Спросите у FixBot
  9. Button Controller Board Replacement: шаг 9, изображение 1 из 1
    • Peel away the glue connecting the red and black wire with the PCB board.
    Спросите у FixBot
  10. Button Controller Board Replacement: шаг 10, изображение 1 из 1
    • Using a soldering wick and a soldering iron, remove the solder from the red and black wire ends on the other side of the board.
    • For more information on soldering, refer to iFixit's soldering guide.
    Спросите у FixBot
Заключение
Jerrell
Участник с: 04/23/14
730 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 11-50, Amido Spring 2014 Участник Cal Poly, Team 11-50, Amido Spring 2014
CPSU-AMIDO-S14S11G50
4 членов
Автор 10 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 59
За всё время: 1,477
