Введение
A damaged or malfunctioning prop arm is a common issue caused by crashes or strenuous flight with your DJI Mavic Mini and will put the drone out of commission until resolved. This guide will walk you through the steps to remove and replace any prop arms you may need to fix to get your drone back in the air.
A basic knowledge of soldering is recommended before beginning this repair as several connection on the main board must be removed and re-soldered and major errors in this process could permanently impact the drone. iFixit's guide to soldering is linked here as well as later in the guide if you need to learn or refresh your skills.
Выберете то, что вам нужно
Orient the DJI Mavic Mini so that the camera faces away.
Use your finger to depress the lip on the panel until the lid becomes ajar.
Flip the panel up to expose the battery module.
Depress the locking mechanism on the battery module to release the lock.
Pull the battery straight out of the casing.
Check the battery pins on the DJI Drone for corrosion or warping. If either of these conditions are present, replacing the battery module may not help resolve the issue at hand.
Check the pin receptacles on the battery module for blockages.
Remove the top panel of the drone by prying open the seam around the device using your fingers or an iFixit opening tool.
Remove the three 5mm J000 screws located on top of the main board cover.
Remove the main board cover panel.
Flip the drone over and use a soldering kit to remove the power cables from the motherboard.
If new to soldering, a helpful guide can be found at Soldering Skills.
Orient the drone so that the props face the upside down and remove the two 3.5 mm J000 screws from the prop arm being replaced.
Flip the drone over and use the tweezers to apply pressure to the metal core of the prop arm pin.
Flip the drone back over and use fingers or tweezers to remove the prop arm pin from its socket.
