Введение
This guide demonstrates how to replace the landing gear on the DJI Phantom 2 Vision. When completing this guide, make sure to clean any residue that may be surrounding the screws before beginning, as doing this will ensure no over or under-tightening of screws may occur.
Note: The drone we worked on already had the propellers removed. However, you will need to remove the propellers before Step 4. Refer to the DJI Phantom 2 Vision+ Propellers Removal for detailed instructions, as the process is identical.
Выберете то, что вам нужно
The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
Remove the battery from the compartment by pinching the top and bottom pressure points near the center and pulling the battery towards you.
Flip the drone over so the bottom is facing up.
Use a Phillips #00 screwdriver to remove the four 6 mm screws.
To access the screws, slowly pull back on the mount in the opposite direction.
Slowly lift the gimbal housing from the device.
Gently disconnect the camera cable from the cable connected to the motherboard.
Push on alternating sides of the connector and pull straight away from the socket.
Locate Landing gears, This should be on the bottom of the drone Holding it up if flipped right side up.
Unscrew each of the 8(9mm) screws using a #1 Philips head bit. These should be near the base of the drone, 2 by each leg of the landing gear.
