DJI Phantom 2 Vision Outer Shell Replacement
Выберете то, что вам нужно
  1. DJI Phantom 2 Vision Outer Shell Replacement, Battery: шаг 1, изображение 1 из 1
    • The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
    • The "battery" shown in the image is for illustrative purposes only. Since the original battery was missing, we constructed this one to demonstrate the repair process. The actual battery will not stick out this much.
  2. DJI Phantom 2 Vision Outer Shell Replacement: шаг 2, изображение 1 из 2 DJI Phantom 2 Vision Outer Shell Replacement: шаг 2, изображение 2 из 2
    • Remove the battery from the compartment by pinching the top and bottom pressure points near the center and pulling the battery towards you.
  3. DJI Phantom 2 Vision Outer Shell Replacement: шаг 3, изображение 1 из 1
    • Clean the battery compartment using cotton swabs and isopropyl alcohol or pressurized air to remove any debris or dust inside.
    • Repeat these steps after every battery replacement to prevent damage to the drone’s internal components.
  4. DJI Phantom 2 Vision Outer Shell Replacement, Outer Shell: шаг 4, изображение 1 из 2 DJI Phantom 2 Vision Outer Shell Replacement, Outer Shell: шаг 4, изображение 2 из 2
    • Remove the propellers before taking off the top shell. Refer to the DJI Phantom 2 Vision+ Propellers Removal for detailed instructions, as the process is identical.
    • Flip the device so the motors are facing down.
    • Remove four 6 mm screws next to the landing gear on each arm using a 2 mm Hex key.
  5. DJI Phantom 2 Vision Outer Shell Replacement: шаг 5, изображение 1 из 1
    • Remove eight 9 mm screws using a 2 mm Hex key.
    • Remove four 9 mm screws using a Phillips #00 screwdriver.
  6. DJI Phantom 2 Vision Outer Shell Replacement: шаг 6, изображение 1 из 2 DJI Phantom 2 Vision Outer Shell Replacement: шаг 6, изображение 2 из 2
    • Slowly lift the shell off the device.
    • Disconnect the GPS wire from the motherboard.
Заключение
Dylan Ponder
Участник с: 09/15/24
386 Репутация
Автор 4 руководств
Команда
Austin Community College, Team 7-1, Watkins Fall 2024 Участник Austin Community College, Team 7-1, Watkins Fall 2024
AUSTINCC-WATKINS-F24S7G1
4 членов
Автор 5 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 154
