Dell Inspiron 13-7352 Battery Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 13-7352 Battery Replacement, Battery: шаг 1, изображение 1 из 3 Dell Inspiron 13-7352 Battery Replacement, Battery: шаг 1, изображение 2 из 3 Dell Inspiron 13-7352 Battery Replacement, Battery: шаг 1, изображение 3 из 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Battery Replacement: шаг 2, изображение 1 из 2 Dell Inspiron 13-7352 Battery Replacement: шаг 2, изображение 2 из 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Battery Replacement: шаг 3, изображение 1 из 1
    • Gently remove the battery from the rest of the device.
Заключение
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 человек успешно провели ремонт по этому руководству.
Mikinna Martin
Участник с: 09/25/15
461 Репутация
Автор 2 руководств
Команду
University of Tampa, Team 1-5, Whiteside Fall 2015 Участник University of Tampa, Team 1-5, Whiteside Fall 2015
UT-WHITESIDE-F15S1G5
3 членов
Автор 6 руководств
3Комментарии к руководству
Last I looked up for a different model there was a video..
pc2053 - Ответить
Hello,
My Dell Inspiron 13-7352 won't turn on; I was using it when there was power outage and I totally drained the battery and it went off automatically, after the power came back I charged it the whole night but it still totally doesn't turn on. I tried to long-press the power button but nothing happens. I am 99% sure that the reason was using it on battery until the whole charge was gone. Please help!
jobgondwe - Ответить
My Dell did the same thing. I followed the above instructions to remove the battery and then put it right back in. Plugged into power and wa-la...it powered up. So simple. Thanks.
pcoladeb - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 4
За последние 30 дней: 27
За всё время: 25,110
