Dell Inspiron 3501 Battery Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: шаг 1, изображение 1 из 2 Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: шаг 1, изображение 2 из 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips screwdriver to remove the seven screws securing the back cover:
    • Three 5 mm-long screws
    • Four 7.5 mm-long screws
    • Loosen the three captive screws.
  2. Dell Inspiron 3501 Battery Replacement, Unclip the front corners: шаг 2, изображение 1 из 2 Dell Inspiron 3501 Battery Replacement, Unclip the front corners: шаг 2, изображение 2 из 2
    • Flip the laptop upright and open the lid so that the keyboard is exposed.
    • Insert an opening pick between the front right corner of the back cover and the chassis.
    • Pry upward to release the retaining clips holding the cover.
    • You'll hear clicks whenever a clip is released.
    • Repeat this procedure for the opposite corner.
  3. Dell Inspiron 3501 Battery Replacement, Unclip the front edge: шаг 3, изображение 1 из 2 Dell Inspiron 3501 Battery Replacement, Unclip the front edge: шаг 3, изображение 2 из 2
    • Insert an opening pick between the front edge of the back cover and the chassis, near the trackpad.
    • Pry upward to release the clips along the front edge of the laptop.
  4. Dell Inspiron 3501 Battery Replacement, Remove the back cover: шаг 4, изображение 1 из 3 Dell Inspiron 3501 Battery Replacement, Remove the back cover: шаг 4, изображение 2 из 3 Dell Inspiron 3501 Battery Replacement, Remove the back cover: шаг 4, изображение 3 из 3
    • Close the screen to the laptop and flip it over.
    • Pull the left side of the back cover away from the frame and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
  5. Dell Inspiron 3501 Battery Replacement, Disconnect the battery: шаг 5, изображение 1 из 2 Dell Inspiron 3501 Battery Replacement, Disconnect the battery: шаг 5, изображение 2 из 2
    • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
  6. Dell Inspiron 3501 Battery Replacement, Unfasten the battery: шаг 6, изображение 1 из 2 Dell Inspiron 3501 Battery Replacement, Unfasten the battery: шаг 6, изображение 2 из 2
    • Use a Phillips screwdriver to remove the three 3.3 mm-long screws securing the battery.
  7. Dell Inspiron 3501 Battery Replacement, Remove the battery: шаг 7, изображение 1 из 3 Dell Inspiron 3501 Battery Replacement, Remove the battery: шаг 7, изображение 2 из 3 Dell Inspiron 3501 Battery Replacement, Remove the battery: шаг 7, изображение 3 из 3
    • Lift the battery straight out of its recess and remove it.
Заключение
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
Участник с: 01/16/22
125 150 Репутация
Автор 582 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 439 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 24
За последние 30 дней: 79
За всё время: 1,242
