Введение
In this guide, we will show you how to remove and replace the battery.
Выберете то, что вам нужно
Turn the tablet over.
Remove the screws that secure the back-cover assembly to the display assembly.
Using a plastic scribe, pry up along the edges of the back-cover assembly.
Carefully, lift the back-cover assembly and turn it over.
Remove the screws that secure the battery to the back-cover assembly.
Disconnect the battery cable from the system board.
Lift the battery, along with its cable, off the back-cover assembly.
4 участников успешно повторили данное руководство.
Один комментарий
The 4 screws on the edge are NOT phillips head screws. They appear to be Tork.
