Введение
Use this guide to remove or replace the back cover of your Fairphone 3.
Выберете то, что вам нужно
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
Pry the back cover up to start separating its plastic clips.
Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
Lift the back cover to release the rest of the plastic clips and remove it.
6 человек успешно провели ремонт по этому руководству.
