Введение
Use this guide to replace the loudspeaker in your Fairphone 4
Выберете то, что вам нужно
Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
Pry the back cover up to start separating its plastic clips.
Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
Slide along the left side of the phone to loosen the plastic clips.
Lift the back cover to release the rest of the plastic clips and remove it.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Lift the battery out of its recess and remove it.
Remove the battery.
Use an opening pick to slide beneath the loudspeaker.
Slide the opening pick to the right side of the loudspeaker to release the clips that hold it in place.
Slide the opening pick to the left side of the loudspeaker to release the clips that hold it in place.
Twist the opening pick to lift up the loudspeaker.
Grab the loudspeaker and flip it towards the bottom to remove it.
