Fairphone 5 Earpiece Speaker Replacement
Выберете то, что вам нужно
  1. Fairphone 5 Earpiece Speaker Replacement, Prepare your phone for disassembly: шаг 1, изображение 1 из 1
    • Unplug all cables and power down your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Fairphone 5 Earpiece Speaker Replacement, Pry up the back cover: шаг 2, изображение 1 из 2 Fairphone 5 Earpiece Speaker Replacement, Pry up the back cover: шаг 2, изображение 2 из 2
    • Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right of the back cover.
    • Pry up the back cover to release the bottom right corner clips.
  3. Fairphone 5 Earpiece Speaker Replacement, Remove the back cover: шаг 3, изображение 1 из 3 Fairphone 5 Earpiece Speaker Replacement, Remove the back cover: шаг 3, изображение 2 из 3 Fairphone 5 Earpiece Speaker Replacement, Remove the back cover: шаг 3, изображение 3 из 3
    • Grip the bottom right corner of the back cover with one hand and brace the phone frame with the other.
    • Lift the back cover away from the phone to release the clips around its perimeter.
    • Remove the back cover.
    • During reassembly, align the back cover over the phone and press along the perimeter until all clips snap back into place.
  4. Fairphone 5 Earpiece Speaker Replacement, Remove the battery: шаг 4, изображение 1 из 3 Fairphone 5 Earpiece Speaker Replacement, Remove the battery: шаг 4, изображение 2 из 3 Fairphone 5 Earpiece Speaker Replacement, Remove the battery: шаг 4, изображение 3 из 3
    • Use your fingernail, or a pry tool like a spudger, to lift the battery by its tab along the bottom edge.
    • Remove the battery.
    • During reassembly, slide the top edge of the battery into its recess in the frame before pressing the battery into place.
  5. Fairphone 5 Earpiece Speaker Replacement, Unfasten the connector cover: шаг 5, изображение 1 из 2 Fairphone 5 Earpiece Speaker Replacement, Unfasten the connector cover: шаг 5, изображение 2 из 2
    • Use a Phillips driver to remove the 3.9 mm-long screw securing the top unit connector cover at the bottom left corner.
    • The connector cover is labeled with a "1" and a triangle pointing downward.
  6. Fairphone 5 Earpiece Speaker Replacement, Pry up the connector cover: шаг 6, изображение 1 из 3 Fairphone 5 Earpiece Speaker Replacement, Pry up the connector cover: шаг 6, изображение 2 из 3 Fairphone 5 Earpiece Speaker Replacement, Pry up the connector cover: шаг 6, изображение 3 из 3
    • Insert your fingernail, or a pry tool like a spudger, under the notch at the left edge of the connector cover.
    • Pry up the cover to separate it from the top unit.
    • The cover is connected to the top unit by a plastic cord. Don't try to completely remove it from the top unit.
  7. Fairphone 5 Earpiece Speaker Replacement, Disconnect the top unit: шаг 7, изображение 1 из 2 Fairphone 5 Earpiece Speaker Replacement, Disconnect the top unit: шаг 7, изображение 2 из 2
    • While holding the cover out of the way, use a spudger to pry up and disconnect the top unit press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  8. Fairphone 5 Earpiece Speaker Replacement, Unfasten the top unit: шаг 8, изображение 1 из 2 Fairphone 5 Earpiece Speaker Replacement, Unfasten the top unit: шаг 8, изображение 2 из 2
    • Use a Phillips driver to remove the six 4.9 mm‑long screws securing the top unit.
  9. Fairphone 5 Earpiece Speaker Replacement, Remove the top unit: шаг 9, изображение 1 из 3 Fairphone 5 Earpiece Speaker Replacement, Remove the top unit: шаг 9, изображение 2 из 3 Fairphone 5 Earpiece Speaker Replacement, Remove the top unit: шаг 9, изображение 3 из 3
    • Insert the flat end of a spudger under the screw hole along the bottom edge of the top unit.
    • Pry up to release the clips securing the top unit to the phone frame.
    • During reassembly, insert the top edge of the top unit at a downward angle into the frame before pressing it down and re-engaging the clips.
  10. Fairphone 5 Earpiece Speaker Replacement, Remove the earpiece speaker: шаг 10, изображение 1 из 3 Fairphone 5 Earpiece Speaker Replacement, Remove the earpiece speaker: шаг 10, изображение 2 из 3 Fairphone 5 Earpiece Speaker Replacement, Remove the earpiece speaker: шаг 10, изображение 3 из 3
    • Insert the tip of a spudger under the bottom left corner of the earpiece speaker press connector.
    • Pry up to disconnect the earpiece speaker press connector.
    • Lift the earpiece speaker out of its slot in the frame and remove it.
Заключение
Alex Diaz-Kokaisl
Участник с: 01/16/22
161 984 Репутация
Автор 769 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 413 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 385
