Введение
Use this guide to replace the Wi-Fi card in your Framework 16" laptop.
The Framework 16" laptop comes with an AMD RZ616 6E Wi-Fi card. This is also the same model sold on their website.
Note: the laptop used in this guide is a generic setup of one US keyboard, one numpad module, and two touchpad spacers. Your setup might vary, but the procedure should remain the same.
Выберете то, что вам нужно
Use your fingernail to pull out the two Input Module latches and unlock them.
Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
Lift the touchpad spacer off the laptop and remove it.
Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
Lift the touchpad and remove it.
Place the touchpad flat on its cutout so its clips are properly aligned.
Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
Grip the two pull tabs along the bottom of the keyboard.
Lift the pull tabs until the keyboard magnets release.
Remove the keyboard.
Grip the pull tab at the bottom of the numpad.
Lift the pull tab until the numpad magnets release.
Remove the numpad.
Grip the black pull tab on the midframe cable press connector.
Lift up to disconnect the midframe cable.
Use a T5 Torx screwdriver to loosen the 16 captive screws securing the midframe.
Use your fingernail to lift the bottom edge of the midframe enough to grip it with your fingers.
Use a T5 Torx screwdriver to loosen the three captive screws securing the battery.
Grip the black pull tab at the top of the battery.
Lift the pull tab to disconnect the battery connector.
Remove the battery.
Use a T5 Torx screwdriver to loosen the captive screw securing Wi-Fi card.
Slide the clear Wi-Fi card cover straight off the card and remove it.
Grip the end of the Wi-Fi card with the screw hole and slide it out of its socket.
Insert the flat end of a spudger under one of the coaxial connectors, where the cable meets the metal head.
Lift the spudger straight up to disconnect the coaxial cable.
Repeat for the other coaxial cable and remove the Wi-Fi card.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Еще один человек закончил это руководство.
