Введение
Use this guide to replace the ice bin in your Frigidaire Side by Side refrigerator.
The ice bin stores ice for dispensing through the door or lifting the flap door on the bin itself. It also contains an auger device that feeds the ice into a chute that leads to the door dispensing opening.
If the ice bin is not fully seated, dispensing problems can occur. The bin's auger can also have problems, either a bent shaft or bad bearings. Either of these auger problems will require bin removal and possibly replacement if the bin is damaged.
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Open the freezer door.
Grasp the lower portion of the front of the ice bin.
Lift it slightly and pull it out toward the front of the refrigerator.
