Fujifilm X30 Motherboard Replacement
Выберете то, что вам нужно
  1. Fujifilm X30 Motherboard Replacement, Battery: шаг 1, изображение 1 из 2 Fujifilm X30 Motherboard Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn the camera upside down.
    • Place your thumb on the switch, and slide it towards the center of the camera.
    • The compartment will pop open.
  2. Fujifilm X30 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Once you have the battery compartment open, slide the orange tab away from the battery until it ejects.
  3. Fujifilm X30 Motherboard Replacement: шаг 3, изображение 1 из 1
    • Pull the battery out.
  4. Fujifilm X30 Motherboard Replacement, Motherboard: шаг 4, изображение 1 из 3 Fujifilm X30 Motherboard Replacement, Motherboard: шаг 4, изображение 2 из 3 Fujifilm X30 Motherboard Replacement, Motherboard: шаг 4, изображение 3 из 3
    • Begin by removing the outside screws using a Phillips #000 Screwdriver:
    • Remove the three 3.6 mm silver screws located on the bottom of the camera.
    • Remove all four of the 4.7 mm screws from the sides of the camera.
  5. Fujifilm X30 Motherboard Replacement: шаг 5, изображение 1 из 2 Fujifilm X30 Motherboard Replacement: шаг 5, изображение 2 из 2
    • Remove all screws below using a Phillips #000 Screwdriver:
    • Lift up the screen and remove the two 4.5 mm screws located in the bottom corners.
    • Remove the 4.0 mm screw that is located behind the screen and directly under the eye piece.
  6. Fujifilm X30 Motherboard Replacement: шаг 6, изображение 1 из 1
    • Carefully lift up the bottom piece of the camera to remove it.
  7. Fujifilm X30 Motherboard Replacement: шаг 7, изображение 1 из 1
    • Do not pull hard when removing the backing because it could rip the orange strip attached to the motherboard.
    • Gently pull off the back of the camera from the left side so that it is partially open.
    • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it
    • Refer to the next step to see pictures of how to properly use the spudger when removing a strip.
  8. Fujifilm X30 Motherboard Replacement: шаг 8, изображение 1 из 3 Fujifilm X30 Motherboard Replacement: шаг 8, изображение 2 из 3 Fujifilm X30 Motherboard Replacement: шаг 8, изображение 3 из 3
    • For all five indicated orange strips:
    • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it.
  9. Fujifilm X30 Motherboard Replacement: шаг 9, изображение 1 из 1
    • For the last orange strip located behind the top strip:
  10. Fujifilm X30 Motherboard Replacement: шаг 10, изображение 1 из 1
    • This step is required if you are doing a full disassembly, but can be skipped if you are only removing the motherboard.
    • For the two orange strips attached to the capacitor circuitboard:
  11. Fujifilm X30 Motherboard Replacement: шаг 11, изображение 1 из 3 Fujifilm X30 Motherboard Replacement: шаг 11, изображение 2 из 3 Fujifilm X30 Motherboard Replacement: шаг 11, изображение 3 из 3
    • Remove all screws listed below using a Phillips #000 screwdriver:
    • Remove the two 3.4 mm screws at the bottom of the silver plate.
    • Hold back the clear strip to reveal a 2.8 mm screw on the left of the silver plate and remove it.
    • Peel back the copper plate.
  12. Fujifilm X30 Motherboard Replacement: шаг 12, изображение 1 из 1
    • Remove the three 2.6 mm screws located in the top two corners and the bottom right corner of the motherboard using a Phillips #000 screwdriver.
  13. Fujifilm X30 Motherboard Replacement: шаг 13, изображение 1 из 2 Fujifilm X30 Motherboard Replacement: шаг 13, изображение 2 из 2
    • Tilt up the motherboard to locate the black, grey, and red wires.
    • Desolder these wires in order to completely remove the motherboard.
    • You can learn about soldering techniques here.
Заключение
2 участников успешно повторили данное руководство.
Tori Baker
Участник с: 01/11/16
262 Репутация
1 руководство автора
Команда
Cal Poly, Team 70-3, Forte Winter 2016 Участник Cal Poly, Team 70-3, Forte Winter 2016
CPSU-FORTE-W16S70G3
5 членов
Автор 4 руководств
2 Комментариев
On step 11 becareful not to detach flex surface from aluminium plate. You could end up braking CCD contacts as I did.
arnau COSTA BEAL - Ответить
Hello, can anybody tell me where i can find the Fuji X30 Motherboard as a spare part? Mine is broken and i don’t want to throw away the camera…. but I don’t find any shop. Thanks for help! Cheers
Dan - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 19
За последние 30 дней: 66
За всё время: 3,046
