Garmin Vívoactive 4 Battery Replacement
Выберете то, что вам нужно
  1. Garmin Vívoactive 4 Battery Replacement, Watch Band: шаг 1, изображение 1 из 1
    • Flip the watch on its back to reveal the watch band connection pins.
  2. Garmin Vívoactive 4 Battery Replacement, Remove Bands: шаг 2, изображение 1 из 3 Garmin Vívoactive 4 Battery Replacement, Remove Bands: шаг 2, изображение 2 из 3 Garmin Vívoactive 4 Battery Replacement, Remove Bands: шаг 2, изображение 3 из 3
    • Wedge your fingernail or the tip of a spudger underneath the watch band's small metal pin.
    • Push on the pin to release the strap from it's hinge.
    • Pull the strap away from the watch to disconnect it.
    • The strap will not pull away if the pin isn't fully pushed in.
  3. Garmin Vívoactive 4 Battery Replacement: шаг 3, изображение 1 из 1
    • With both straps removed, a new replacement watch band may be inserted.
  4. Garmin Vívoactive 4 Battery Replacement, Screen: шаг 4, изображение 1 из 1
    • Use a heatgun to loosen the adhesive beneath the screen, it should take a 5-10 minutes for adhesive to loosen.
    • Handle the watch with care to avoid burning yourself after it has been heated. Review the How to Use a Heat Gun to Soften Adhesive guide.
  5. Garmin Vívoactive 4 Battery Replacement: шаг 5, изображение 1 из 2 Garmin Vívoactive 4 Battery Replacement: шаг 5, изображение 2 из 2
    • Wedge a thin opening tool or your iFixit Jimmy in between the seam where the screen and the watch’s housing connect.
    • Pry the screen off the device.
    • There is a cable underneath the screen that needs to be disconnected - be careful not to rip it.
    • Work quickly so the adhesive doesn’t cool too much.
  6. Garmin Vívoactive 4 Battery Replacement: шаг 6, изображение 1 из 3 Garmin Vívoactive 4 Battery Replacement: шаг 6, изображение 2 из 3 Garmin Vívoactive 4 Battery Replacement: шаг 6, изображение 3 из 3
    • Carefully disconnect both cables from the motherboard by placing the tip of your spudger under the edge of the connector, and prying the connector straight up from its socket.
  7. Garmin Vívoactive 4 Battery Replacement: шаг 7, изображение 1 из 1
    • Remove the screen.
  8. Garmin Vívoactive 4 Battery Replacement, Motherboard: шаг 8, изображение 1 из 1
    • Carefully peel off the ribbon tape that is holding down the motherboard.
  9. Garmin Vívoactive 4 Battery Replacement: шаг 9, изображение 1 из 1
    • Place the tip of your spudger under the edge of the connector, and pry the connector straight up from its socket to disconnect the battery from the motherboard.
    • Do this carefully to avoid ripping the cable.
  10. Garmin Vívoactive 4 Battery Replacement: шаг 10, изображение 1 из 3 Garmin Vívoactive 4 Battery Replacement: шаг 10, изображение 2 из 3 Garmin Vívoactive 4 Battery Replacement: шаг 10, изображение 3 из 3
    • Use a Phillips #00 screwdriver to remove the 3.2 mm screw on the motherboard.
    • Use a Phillips #00 screwdriver to remove the 4.8 mm screw on the motherboard.
  11. Garmin Vívoactive 4 Battery Replacement: шаг 11, изображение 1 из 3 Garmin Vívoactive 4 Battery Replacement: шаг 11, изображение 2 из 3 Garmin Vívoactive 4 Battery Replacement: шаг 11, изображение 3 из 3
    • Pull the battery cable up to dislodge the motherboard.
    • Gently remove the motherboard from the socket.
    • The motherboard may get caught under the housing due to the clips on the edge.
  12. Garmin Vívoactive 4 Battery Replacement, Battery: шаг 12, изображение 1 из 2 Garmin Vívoactive 4 Battery Replacement, Battery: шаг 12, изображение 2 из 2
    • Use the pointed tip of a spudger to carefully push on each side of the battery connector to disconnect the battery from the motherboard.
  13. Garmin Vívoactive 4 Battery Replacement: шаг 13, изображение 1 из 3 Garmin Vívoactive 4 Battery Replacement: шаг 13, изображение 2 из 3 Garmin Vívoactive 4 Battery Replacement: шаг 13, изображение 3 из 3
    • Use a spudger to pry the battery from the case.
    • Be careful not to damage any surrounding components.
    • There is an adhesive holding the battery down. Use an iOpener if it is too difficult to remove the battery with the spudger alone.
Заключение
2 участников успешно повторили данное руководство.
Bryan Chavez
Участник с: 11/01/23
380 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team 1-3, Petersen Fall 2023 Участник UMass Dartmouth, Team 1-3, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G3
4 членов
Автор 6 руководств
Один комментарий
There's a warning about the battery connectors in this reddit thread https://www.reddit.com/r/GarminWatches/c...
Look for a comment by Willthedoctor from Nov 2023
Dereko - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 45
За последние 7 дней: 349
За последние 30 дней: 1,353
За всё время: 4,691
